90 Users Online (88 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:17 PM
Forums >> Workflow & Implementation >> API & Third Party Apps >> Problems exporting from Revit MEP 2009 into Navisworks Manage 2009
Wed, Jun 24, 2009 at 8:17:17 AM | Problems exporting from Revit MEP 2009 into Navisworks Manage 2009
Kobbs
Kobbs Avatar
We're having a bit of trouble here with what should be a straightforward procedure, so hopefully someone can shed some light on things.
We're using the Navis export tool to export out Arch & MEP models into Navisworks, but everytime we try, the models always come in at the wrong size (waaaaaaaaay smaller than they actually are).
We have made sure that the units in the export tool are set to millimetres, and that it is set to export the entire project, and we have made sure that the units in Navisworks are also set to millimetres, but to no avail. Every time we're getting models that seem to be about 300x smaller than they should be.
Has anyone else experienced anything like this?
Exporting to Navisworks 2009
Thu, Mar 5, 2009 at 6:41:39 PM
Revit IFC export and NavisWorks 2009
Tue, Nov 18, 2008 at 11:15:34 AM
Export Issue from revit to navisworks
Thu, Apr 15, 2010 at 9:14:18 AM
In Revit, the Navisworks File Exporter is grayed out on the ribbon menu
Fri, Jun 4, 2010 at 12:42:22 PM
Revit MEP 2009 family to be used in Revit Architecture 2009
Fri, Feb 6, 2009 at 8:09:24 AM
Page generation time: 2.5707
