49 Users Online (48 Members):
Forums >> Revit Structure >> Tips & Tricks >> Load Bearing Walls hatched
9 Posts No Rating |
Hey, Im trying to find a way to solid fill and wall which is under do resemble a load bearing wall which is under. Is there a way to do this with using a filled region? Any advice would be much appreciated. Thanks
9 Posts No Rating |
without using a filled region**** thanks
See this video from Rkitec :http://gibsonhh.info/revit/video/filterPoche.swf
9 Posts No Rating |
Thanks for the reply. i have made the filter, if i want to put the load bearing walls on the seond floor plan, i put the two plans on the sheet, one on top of the other, but they seems to be blocking each other out, i have also set my filter on transparent, and this still doesnt seem to be working. Any suggestions? If you could have a look at the file ive attached, i would be greatful.
9 Posts No Rating |
Heres a snap shot of what is happening. Ive offset the plans to show the problem. The red walls are the ground loadbearing walls, the other walls are the Level 1 walls.
10 Posts No Rating |
Why all the good ideas always come to someoneelses heads? ________________________________________________________ Uggs ugg boots
Bearing vs. Non-bearing walls |
Wed, Oct 10, 2012 at 3:04:30 PM
Exterior Bearing Walls? |
Tue, Jan 22, 2008 at 8:46:40 AM
Showing Load Bearing Walls from a lower Floor Plan |
Thu, Feb 16, 2012 at 10:02:04 PM
Cut Planes for CMU Bearing Wall Systems |
Thu, Jun 4, 2009 at 6:08:28 PM
Before I Start Copy/Monitor |
Thu, Sep 6, 2012 at 10:19:47 AM
Members: | 2017200 | Objects: | 22947 | Forum Posts: | 152211 | Job Listings: | 3 |
