64 Users Online (63 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:18 PM
Forums >> General Discussion >> Revit Project Management >> building and topography
Tue, Jun 23, 2009 at 6:36:14 AM | building and topography
roque14
Hi i am doing a tutorial about taking topography from a dwg file. Do you even model in revit using topography and if so do you import it from a dwg or do you make it yourself in revit?
thanks
Tue, Jun 23, 2009 at 6:38:25 AM | building and topography
You can do either.  Refer to your tutorials and HELP for more information.
Tue, Jun 23, 2009 at 7:50:59 AM | building and topography
roque14
ideally i wanto to take my revit model into max to render it, how vital is terrain modelling? do you model it all the time or just if it plays a bit part in the design?
Tue, Jun 23, 2009 at 7:53:38 AM | building and topography
I would think that is up to you and your project - not a consensus on this forum.  For us, every site is important be it flat or otherwise.
Tue, Jun 23, 2009 at 8:17:09 AM | building and topography
roque14
ok thanks, do you usually make the terrain prior to the building model or after the model and work the terrain around it?
Building Pad Altering My Topography Surface
Wed, Nov 30, 2011 at 12:02:00 PM
Topography and Building relationship
Tue, Feb 23, 2010 at 1:22:09 PM
New to using Topography & Building Pads
Thu, Jun 17, 2010 at 2:45:10 PM
Topography in elevations
Wed, Mar 4, 2009 at 4:23:07 AM
topography...
Sun, Jun 29, 2008 at 4:11:05 PM
Page generation time: 1.7212
