38 Users Online (36 Members):
Forums >> Revit Building >> Technical Support >> structural concrete beams into wall
![3 Stars: 3 Votes](/images/stars_3.gif) |
How can i show structural concrete beams into a masonary wall when i do a section? the wall always hide the beam and this is not correct. I ve benn trying everything unsuccessfully
![4 Stars: 19 Votes](/images/stars_4.gif) |
In this case I draw a wall, loaded a structural concrete beam and drew it in at the level above the base of the wall. I aligned the top of the wall to the bottom of the beam. What are you trying to do?
5 Posts No Rating |
2 ways i find that work 1. use the beam join command 2. use the align command, this will push the beam to the center of the wall. also you may have to set the wall to be transparent. Pick the wall-choose view graphics-override-by element-check "transparent". This will let you see the beam through the wall
Concrete Columns and Beams cuts through wall... |
Mon, Feb 4, 2013 at 8:10:15 AM
Concrete columns behaviour before and after placing concrete beams |
Tue, Apr 1, 2014 at 1:58:43 AM
Concrete Beams |
Tue, Nov 11, 2008 at 3:33:21 PM
Beams won't intersect or close-up to Structural Columns. Solution ? |
Tue, Oct 18, 2016 at 2:01:11 PM
Joining Beams and Floors - Beams in a Structural Linked File |
Fri, Jun 22, 2018 at 10:07:04 AM
Members: | 2022396 | Objects: | 22974 | Forum Posts: | 152201 | Job Listings: | 3 |
