76 Users Online (74 Members):
Forums >> Revit Building >> Technical Support >> Moving walls and components
2 Posts No Rating |
Lets say that i have built a house in revit (footing, foundation, flooring, exterior walls and interior wall). I decide i want to make the overall dimensions of the house bigger. How do i make it larger without having to individually change the dimensions of all the components such as the flooring system and the foundation walls? Is there a way to move exterior walls and also simultaneously move and keep the foundation walls/flooring/footing directly beneath it?
![4 Stars: 19 Votes](/images/stars_4.gif) |
This depends on how the house is modelled. If you had set up grid lines and constrained the walls to the gridlines, used the walls to define the floors and the roofs by footprint using the wall offset, you could simply move the gridline and everything should move with it. Of course it depends on the complexity and what is constrained to the wall, but defionitely possible.
Also, from a plan view that is full depth, you can window a portion of the building and "stretch" it to a new location. The problem with both tim and my answers is that some elements are constrained to move in only one direction and the only way to move in the other direction is to "disconnect" your elements. However, you are not only disconnecting model elements but all dimesions and tags as well.
Electrical components moving when reloading arch model |
Mon, Jan 5, 2015 at 9:01:02 AM
Revit components popping and moving all over the place |
Tue, Mar 22, 2016 at 3:58:37 PM
Locking electrical components to host |
Wed, Mar 31, 2010 at 3:18:03 PM
moving walls |
Tue, Aug 6, 2013 at 8:54:03 PM
Moving an entire plan |
Mon, Oct 29, 2012 at 7:31:51 AM
Members: | 2022512 | Objects: | 22975 | Forum Posts: | 152203 | Job Listings: | 3 |
