78 Users Online (74 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:18 PM
Forums >> Revit Building >> Technical Support >> Massing
Mon, Jun 22, 2009 at 8:52:56 AM | Massing
GMMcCrossin
I am using Revit Arch. 2009. My problem is I am unexperienced with massing. I can create a profile and a path and send my massing around but i need to create a profile in more than one plane. Is there a simple solution to this?
Feel free to give me anything you have on Massing....
I have Rev. Arch 2009, and Rev. Structure,and MEP 2010
Mon, Jun 22, 2009 at 9:06:30 AM | Massing
Your question is not clear.  A profile by nature is only 2D and you can create that on any plane.  2009 allows you to extrude / revolve or sweep that profile along a 2d or 3d path and it will allow you to blend between two different profiles on parallel planes. But that it is it for 2009 - 2010 allows more manipulation if you need it.
Mon, Jun 22, 2009 at 9:09:08 AM | Massing
GMMcCrossin
I guess what i need to know is how do a create a work plane at a 45 degree angle to start my profile?
Mon, Jun 22, 2009 at 9:18:47 AM | Massing
In either a family or in a project, goto an elevation view and draw your reference plane - then select it and in its properties, give it a name so that you can find it.
BUT - Do you really want to do this.  Most objects are easier to create in normal planes in a family, then by un-checking the "always vertical" parameter in the family settings, the family can be rotated in the project to the angle you want.
why my massing can't not be a solid?
Fri, Feb 11, 2011 at 8:26:43 PM
conceptual massing...undulating roof shape
Thu, Jun 24, 2010 at 3:01:56 PM
Finding Massing Model
Wed, Feb 23, 2011 at 3:54:54 PM
>>>stuck with creating massing form in revit<<< HELP!
Fri, Nov 6, 2009 at 4:07:54 PM
in place massing problems
Thu, Jul 16, 2009 at 6:41:45 AM
Page generation time: 0.7716
