Forums >> General Discussion >> Revit Project Management >> revit plans- basic
Hi guys, im thinking of going from cad to revit. Basically all I do in cad is create presentation plans and elevations with black varying thickness lines on a white background. I assume this can be done in a high quality manner in revit like cad, and can you also copy it into illustrator to put it into high quality like cad?cheers
Hi, and Welcome to Revit World, about your question you can do everything you do in CAD, I can assure you that it is better....
Ok thanks, because really all I do at the moment in cad is doing presentation style plans etc. Apart from the BIM revolution i hear about, i want to be able to be able to easilly bring models into max to render.... I plan to start learning revit tomorrow based on the tutorial/help files from autocad and tutorials/help, is the learning curve steep? or is it easy to grasp in say like a week of high intensive work? cheers
I think you should read the tutorials first then start with something simple....
Hi roque14, and also always be supported by the HELP menu....
REVIT Architecture 2009 Basic Architectural Convention question [ 1 2 ] |
Tue, Oct 21, 2008 at 8:19:58 AM
15
Use Plans via Room Tag? (color plans) |
Tue, Apr 17, 2012 at 9:42:55 AM
site plans and buildings plans |
Tue, Apr 17, 2012 at 8:40:07 AM
Basic Tutorial |
Mon, Apr 4, 2011 at 1:57:38 AM
Complete set of plans |
Wed, Apr 1, 2009 at 10:25:08 PM
Members: | 2115099 | Objects: | 23192 | Forum Posts: | 152320 | Job Listings: | 3 |
