50 Users Online (49 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:18 PM
Forums >> Revit Building >> Technical Support >> Making sketch windows and doors with little detail?
Mon, Jun 22, 2009 at 2:39:56 AM | Making sketch windows and doors with little detail?
McGade
Hi Experts
 I am trying to make some objects that in "coarse" mode will show minimal detail, so it can function as a sketch project. Right now it is my windows that show too much detail. I have attached a picture that shows the level of detail i want my window to show in coarse mode. How can i make i do that? i know its something to do with messing around in family mode. But i am not that good with familys. So if that answer is about editing the families i would like a link to a tutorial, if thats possible Smile
 Kind Regards McGade
Mon, Jun 22, 2009 at 3:57:07 AM | Making sketch windows and doors with little detail?
4 Stars: 203 Votes
You forgot to attach the image, but, YES you must edit the family and change the visibility of the elements in the several modes, when you edit the family and pick in the element in the "options bar" you can see the "visibility" button, pick on that and you can change what you want to see in Plan, in elevation (front/ left...) and when you cut the obj. also you define if you want to see in the several modes or only in one (i.e. coarse, medium and Fine mode)
Good Windows and Doors
Thu, Aug 1, 2013 at 10:35:37 AM
Excluding doors and windows in count
Wed, Feb 15, 2006 at 2:59:06 AM
Exterior windows and doors
Fri, Sep 6, 2013 at 7:39:11 AM
sharing doors/windows between projects
Wed, Mar 24, 2010 at 6:27:51 AM
Door & Window Schedules - how to schedule existing doors and windows
Tue, Feb 3, 2009 at 11:11:40 AM
Page generation time: 0.9686
