67 Users Online (66 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:18 PM
Forums >> Revit Building >> Technical Support >> trying to make custom light fixture w/ 2 light sources - need help
Fri, Jun 19, 2009 at 1:20:26 PM | trying to make custom light fixture w/ 2 light sources - need help
structuresguy
I am trying to make a cylindrical light fixture that has a spot light pointing down and another pointing up.  Each light needs to have separate parameters, so I can control wattage independently.
I can make the fixture and put one spot light in it.  But I can't figure out any way to add a second light source.  Copy and mirror are both greyed out when I select the light source.  Need some help here.  I am working in 2009 and started with the generic light fixture template.  Thanks.
Fri, Jun 19, 2009 at 1:46:25 PM | trying to make custom light fixture w/ 2 light sources - need help
You can do this with a nested light family.  Set the families to shared... you will have to add parameters to the host family that pass the settings through to the hosted family.
You could probably also accomplish this with a group in the project....The host light grouped with a simple light source only.
Fri, Jun 19, 2009 at 2:49:18 PM | trying to make custom light fixture w/ 2 light sources - need help
structuresguy
Thanks, I think I'll try grouping them first, as that sounds a bit easier to do.  I'm not really sure what a nested family is, so hopefully the first will work.  thanks much.
Fri, Jun 19, 2009 at 6:04:48 PM | trying to make custom light fixture w/ 2 light sources - need help
structuresguy
I figured out the nested family, and it worked great.  thanks very much.  there's just so much to learn on this program.
Mon, Jun 22, 2009 at 6:23:46 AM | trying to make custom light fixture w/ 2 light sources - need help
patton
5 Stars: 2 Votes
Well, I thought it might have been an OE problem since that is usually the case. Now that you figured that lighting out maybe you'll get back to work on the structure of the building and stop making fancy pictures. HAHA
Had to get you back there structureguy!! Smile
custom light fixture, Revit 2009
Fri, Mar 11, 2011 at 9:28:45 AM
Opaque light fixture not emitting light
Wed, Dec 18, 2013 at 3:30:35 AM
Add Light Source to Light Fixture
Mon, May 17, 2010 at 1:06:22 PM
Custom Light Fixture
Tue, Apr 23, 2013 at 4:33:19 PM
Light fixture doesn't produce light
Sat, Jun 7, 2008 at 12:39:39 PM
Page generation time: 0.8411
