42 Users Online (41 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:17 PM
Forums >> General Discussion >> Wishlist >> Balusters and Rails
Thu, Jun 18, 2009 at 10:47:31 AM | Balusters and Rails
ttlaff
Trying to locate some concrete or polyurethane baluster and railing .raf's for a high end tuscan style home I'm designing, anyone know where I might find some?
Thu, Jun 18, 2009 at 12:12:57 PM | Balusters and Rails
3.5 Stars: 396 Votes
Did you look in the on-line library ... not in the family area - it's in the samples ... there is a sample project with many different railings.
Fri, Jun 19, 2009 at 7:39:01 AM | Balusters and Rails
ttlaff
thanks Hub but I can't find the on-line library your speaking of, can I get a path or link
thanks brother
Fri, Jun 19, 2009 at 8:12:06 AM | Balusters and Rails
The on-line library location always poped up when you went to load until 2009/2010 - here is the location: http://revit.autodesk.com/library/html/index.html
Note  that the library is 2010 - if that is what you are in, go tol the Revit instractions and help samples tab.  Otherwise, find the same tab in the archived libraries for your issue.  NOTE::::: Look under both metric & imperial samples!
Fri, Jun 19, 2009 at 12:07:06 PM | Balusters and Rails
ttlaff
Oh yeah that library, duh!  Thanks for the direction and I found lots of great stuff there but not what I need, guess this is my motivation to step up and create one of my own.
Thanks for the help
Rail extension at top and bottom of stair
Fri, Jun 6, 2008 at 12:35:34 PM
Baluster rendering
Fri, Jul 2, 2010 at 12:34:16 PM
Sloped Railing / Baluster Cut
Mon, Jan 28, 2008 at 5:19:01 PM
Does anyone have a typical paling woodend fence with
Sat, Aug 8, 2009 at 2:02:59 AM
Balusters
Wed, Aug 13, 2008 at 2:39:04 PM
Page generation time: 0.2312
