17 Users Online (16 Members):
Forums >> Revit Building >> Technical Support >> Door Schedule Filter Revit 2009
2 Posts No Rating |
Hi, I am having issue trying to filter my door schedule. I've got 10 buildings named HA, HB, HC, HD, HE, HF, HG, HH, HJ, HK. I want my door schedule to just show HE and HF since the other buildings are exact duplicate of these two buildings. I went into the door schedule properties and did a filter for "Mark"..."Contains"...."HE". On the second row...And "Mark"..."Contains"...."HF". Somehow after i click OK....all the data disappears. However, if I did a filter the other way...and pick "Does not contain"...and choose HA, HB, HC, etc...then it filters out HA, HB and HC. Can anyone help me on this? It seems very strange that I can't filter out the items that I want. thanks,
Think about this, your filter is progressive - the first line filters only for those with HE ... everything else is gone...how can it find any HF's... Now if Revit allowed an "OR" instead of the "AND" then your filter would work.
2 Posts No Rating |
Thanks, I think that if i made a new parameter and put all the doors i want to show on that parameter (for example: name them all to 1). Then i can filter that parameter and show all that contains "1". thanks for your help.
30 Posts No Rating |
Yeh... For same kind of schedules, I create a parameter called 'Building Name' and I specify Building Name in each component that's being scheduled - in your case, doors.
Door Schedule not fitting on one sheet |
Mon, Jul 7, 2008 at 2:33:28 PM
Customized Door Schedule Needs Help |
Thu, Aug 25, 2011 at 5:53:09 PM
Schedule Help : Adding multiple filter headings under one filter |
Thu, Aug 1, 2013 at 12:22:17 PM
Door Schedule help. |
Thu, Sep 10, 2015 at 1:41:52 PM
How to Print Large Door Schedules Revit 2009 |
Wed, Jan 21, 2009 at 12:28:45 PM
Members: | 2056090 | Objects: | 23069 | Forum Posts: | 152281 | Job Listings: | 3 |
