62 Users Online (61 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:17 PM
Forums >> Revit Building >> Technical Support >> Masking/Filled Region Does not work in Roof Plan
Thu, Jun 18, 2009 at 7:43:24 AM | Masking/Filled Region Does not work in Roof Plan
ryan81
See the attached.
 I am doing an addition in the corner of two existing buildings.  The existing buildings have 3'-0" Overhangs.  I have hidden the roof of the existing building so that I can see the entire new roof below.
For a clean drawing I would like to draw a masking region over the existing buildings so that all I see is the outline of the existing building - you will notice that you can see walls because I have hidden the existing roof.  When I try and draw a masking region, it doesn't cover anything up.
My view is set to hidden line.
Please help!
 Thanks!
Thu, Jun 18, 2009 at 9:18:25 AM | Masking/Filled Region Does not work in Roof Plan
Masking regions work ... transparent filled regions would not work... but another way - just window cross the existing inside the exterior walls and right click - hide in view ... or you could be creative and do a plan region....
Masking Region Fill Region Problem
Mon, Mar 10, 2008 at 11:06:24 AM
Masking Regions and Filled Regions - Which Is In Front?
Fri, Oct 28, 2011 at 2:26:55 PM
Masking region in roof plan
Tue, Feb 24, 2009 at 3:14:03 PM
Filled Regions Not Masking?
Tue, May 12, 2009 at 5:45:16 PM
Line tool shortcut when in a masking/filled region..
Mon, Feb 14, 2011 at 4:00:46 AM
Page generation time: 2.5174
