90 Users Online (86 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:17 PM
Forums >> Revit Building >> Technical Support >> stair sections and hidden lines
Tue, Jul 26, 2005 at 7:00:44 PM | stair sections and hidden lines
rubiks cube
Hello, I have made a steel switch back stair case on metal stringers for an office building. Essentially a standard exit stairway going down 3 floors. The stair goes up, wraps around a wall blah blah. I do a section through the stairs. My problem is I cannot graphically represent the stair hidden behind the wall. I would like it to show in a dotted line as hidden. Of course I remove my center wall, and stil cannot change the appearance of just the hidden stair...the stringer is in the way! Any one got any ideas on how to do this? cc
Tue, Jul 26, 2005 at 11:24:49 PM | RE: stair sections and hidden lines
eldados
eldados Avatar
4.5 Stars: 8 Votes
go to your section and turn to wireframe, with the detail line pick your risers and threads, back to hidden and off you go...
Wed, Jul 27, 2005 at 2:42:56 AM | RE: stair sections and hidden lines
Mr Spot
Mr Spot Avatar
4.5 Stars: 93 Votes
Instead of detail lines use the linework tool to have the lines be associated to the stair and thus will adjust should the riser height change...
Wed, Jul 27, 2005 at 3:02:29 AM | RE: stair sections and hidden lines
eldados
eldados Avatar
4.5 Stars: 8 Votes
good idea spoty! Smile
Stair Sections, show Treads Beyond in Hidden Lines, no Linework, no Detail Lines
Tue, Jul 1, 2014 at 8:08:48 PM
Yep! That's me
Sat, Oct 13, 2012 at 12:24:55 PM
Show hidden lines
Wed, Apr 16, 2008 at 5:52:55 PM
Show Hidden Lines Tool and Detail Elements
Fri, Nov 22, 2013 at 8:48:50 AM
Placed Sections on Sheet, Plan Cut Lines Disappeared, But the Sections Remain
Sun, Dec 2, 2012 at 7:34:52 PM
Page generation time: 5.6294
