59 Users Online (56 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:17 PM
Forums >> Revit Building >> Technical Support >> Extrusions within a project? (2010)
Wed, Jun 17, 2009 at 3:19:47 PM | Extrusions within a project? (2010)
willisbig
Hello all!
First time poster here. My question is regarding extrusions. My office recently began using Revit Structure 2010. I had in the past been using the 2009 version and seem to remember being able to create extrusions, sweeps, blends, revolves what have you directly inside a project file. Now it seems as though these tools are only available when creating a family. The only similar tool seems to be the In-Place Mass under the Architect & Site tab. Are you able to manipulate an In-Place Mass to bend and change it's shape? Or is there a tool I'm just missing somewhere? I'm sure the answer is simple and I'm just not seeing it, but any help would be greatly appreciated.
 Cheers,
Wed, Jun 17, 2009 at 3:43:29 PM | Extrusions within a project? (2010)
alabaster2513
alabaster2513 Avatar
3.5 Stars: 25 Votes
the regular massing tool you are refering to in 2009 has been replaced in 2010 with the Conceptual Massing tool that is much like sketchup and give you much more function that the old massing tool. If you are looking to stick with the old way of massing just do an in-place family and put it in the Mass category
Wed, Jun 17, 2009 at 3:49:11 PM | Extrusions within a project? (2010)
4 Stars: 203 Votes
If you want the OLD Create-In-Place go to Home>Component>model in place, the OLD mass is in MAssing and Site....
Wed, Jun 17, 2009 at 4:19:45 PM | Extrusions within a project? (2010)
willisbig
Thanks for the quick reply alabaster,
I have created masses using the Conceptual Massing tool and I'm sort of getting the idea of adding multiple profiles to the mass in order to manipulate the shape. What I'm wondering is if there's an easy way of say, using a single profile and having it follow a specific path similar to a sweep. Or do I have to manipulate multiple profiles in order for my shape to follow that path. (I hope I'm making sense here Puh)
What I'm trying to do basically is make an arch that follows a radiused path. Also if it's not too much trouble could someone explain to me how to make an In-Place family?
Thanks for any and all help
Cheers,
Wed, Jun 17, 2009 at 4:23:53 PM | Extrusions within a project? (2010)
willisbig
AHAA...Thanks a bunch Typhoon that's exactly what I'm looking for...
Wed, Jun 17, 2009 at 4:57:54 PM | Extrusions within a project? (2010)
alabaster2513
3.5 Stars: 25 Votes
if you run into that problem again trying to find a command there is a tool built into Revit 2010 you can use. Click the drop down arrow next to the ? mark on the top right of the Revit user interface, there you will find a function called "where is my command?" it outlines where you find commands in the new UI vs the old one.
Revit 2010 - Can't pick a line for plane to draw extrusions - HELP!!!
Thu, Aug 27, 2009 at 3:34:25 AM
Joining extrusions
Tue, Jul 26, 2022 at 3:58:08 PM
extrusions
Thu, Jan 14, 2010 at 12:47:48 PM
Void extrusions showing up orange even when rendered
Fri, Mar 8, 2019 at 1:35:44 PM
naming extrusions
Thu, Oct 10, 2013 at 10:00:24 AM
Page generation time: 1.0000
