59 Users Online (57 Members):
Forums >> Revit Building >> Technical Support >> EXPORTING
![Bimman Avatar](user_avatar/938.jpg)
![1 Stars: 2 Votes](/images/stars_1.gif) |
I am exporting files to dwg and my crop region becaomes a viewport and is turned on in the new dwg file. Is there any way to export with the crop/viewport off so I do not have to go into each sheet and turn it off.
----------------------------------- PWD |
24 Posts No Rating |
yes, we are having similar issues. Because when printing you have the option to turn off the crop box. This option is not there in the export options. Also I tried to make an export layer with 0 thickness for the crop box but that did not work either (export as hidden layer). So we are using a program called scriptEese to turn off the layer in cad (another kind of lisp file) maybe someone else has a better solution.
Dimensions and Exporting |
Fri, Nov 9, 2007 at 2:30:26 PM
Exporting Sections to AutoCAD |
Thu, Jun 16, 2005 at 4:53:41 PM
Exporting FBX from |
Thu, Jul 22, 2010 at 12:36:28 PM
3D DWF Exporting in 9.1 |
Wed, Feb 7, 2007 at 3:39:28 AM
Exporting views for DWG |
Thu, Oct 24, 2019 at 5:52:23 PM
Members: | 2022260 | Objects: | 22975 | Forum Posts: | 152203 | Job Listings: | 3 |
