59 Users Online (57 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:17 PM
Forums >> Revit Building >> Technical Support >> Exporting Elevations Problem
Mon, Jun 15, 2009 at 8:50:38 PM | Exporting Elevations Problem
zilong245
I am having trouble exporting elevations from Revit to Autocad. When I export elevations similar elements (columns,walls,doors.etc.) have the same lineweights, which should not be the case because I want the elements closest to me to be more prominent while the distant objects a bit lighter or grayed out. Is there a workaround to this? Can I somehow import the ctb file I use in my autocad program to Revit so that when I export from Revit the elevations will reflect the lineweights accordingly? Thank you very much for any help on this matter.
Edited on: Mon, Jun 15, 2009 at 8:57:30 PM
Tue, Jun 16, 2009 at 6:52:11 AM | Exporting Elevations Problem
Revit's export to CAD is based on export options that are set in a file.  When you export, click on options and you will be able to reset these.
Problem with Interior elevations
Fri, Feb 13, 2015 at 1:51:29 PM
Dimension problem when exporting Revit to DWG
Tue, Apr 12, 2011 at 11:15:43 AM
exporting
Mon, May 31, 2010 at 10:33:17 AM
Export to AutoCAD issues
Fri, Jan 12, 2007 at 2:32:45 PM
Problem with Exporting to dwg with multiple layers for use in 3D Studio
Mon, Dec 13, 2004 at 5:21:21 AM
Page generation time: 1.0609
