81 Users Online (80 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:17 PM
Forums >> General Discussion >> Revit Project Management >> trouble fininshing a void
Mon, Jun 15, 2009 at 5:14:21 PM | trouble fininshing a void
Cindyg
This Mass has no solid geometry for its Void Forms to cut. They must be deleted, or solid geometry added and cut.
Mon, Jun 15, 2009 at 9:05:05 PM | trouble fininshing a void
brettgoodchild
brettgoodchild Avatar
4 Stars: 17 Votes
A little more info to help out, what are you trying to accomplish?
Are you trying to remove geometry from a system family such as a roof?
If so, try using the generic model catagory instead and create it as a void. By rule, you can't have a void mass, there has to be a solid mass to subtract from...defeats the whole purpose of a mass. You can however,  have a void generic model that can cut geometry from your model... or use the opening tool if you are just trying to cut an opening in a wall, roof, floor and so on.
But again, more info needed.
HTH
Edited on: Mon, Jun 15, 2009 at 9:09:29 PM
"You cannot escape the responsibility of tomorrow by evading it today. "
                             ~ Abraham Lincoln
Mon, Jun 22, 2009 at 8:46:26 PM | trouble fininshing a void
JunK
I have worked around this same problem before by creating a solid mass in the family just so that Revit gets what it wants, then turn off its visibility. You can keep the void and do what you want with it.
One minor problem in doing this way is finding a way to select the in-place family afterwards for editing because you will be trying to select something which is invisible. So think of naming for the model when you create it. It may be helpful to recognize it in the list of objects.
 Jun K.
Trouble with void forms and parametrics in families
Mon, Jul 4, 2011 at 9:28:29 AM
Voids in familes
Wed, Jan 30, 2008 at 1:32:40 PM
Can't get VOID to cut my countertops... [ 1 2 ]
Fri, Feb 25, 2011 at 1:41:44 PM
17
Void Masses
Fri, Oct 3, 2008 at 4:11:06 PM
void in family is yellow
Mon, Mar 12, 2018 at 12:22:43 PM
Page generation time: 0.3543
