67 Users Online (66 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:18 PM
Forums >> Revit Systems >> Technical Support >> Installing Valves on vertical pipes.
Mon, Jun 15, 2009 at 3:04:40 PM | Installing Valves on vertical pipes.
Stingem
Is there a way to install valve components in elevation or section so I can connect them to vertical pipes.
I've been only able to install them in plan view and I can't figure out how to make it choose the vertical pipe in my design. If that's possible at all.
Tue, Sep 15, 2009 at 9:17:29 AM | Installing Valves on vertical pipes.
caveman
I drew a short length of pipe horizontally, added the valve then went to my elevation view and rotated it, then moved it into place and connected it to my existing pipe.
REVIT sum up valves
Wed, Nov 26, 2014 at 4:53:08 PM
Duo pipes - Twin pipes for central heating
Wed, Jan 16, 2019 at 3:48:54 PM
PRINTING COLOR HATCH TO BLACK
Tue, Aug 16, 2011 at 1:59:53 PM
REVIT MEP 2012 Demo Phasing Disconnecting Pipes
Wed, Jul 18, 2012 at 12:20:03 PM
Revit MEP valve problem
Thu, Feb 5, 2009 at 9:01:02 AM
Page generation time: 0.2684
