112 Users Online (111 Members):
Forums >> Revit Structure >> Technical Support >> pan joists
12 Posts No Rating |
I have a pan joist in my building. It tapers a little from top to bottom. Problem is, in framing plan view, I see all four edges of the beam that result from the taper. How can I simplify it to show just two edges like a normal beam? I'd prefer NOT to invisible-line all the unwanted edges out, because I have a lot of them. Thanks!
I don't know what your family is like but you can build families that do not show the model in plan views but show symbollic lines instead. In this case, you would only show one edge (top-bottom?)
Unfortunately, there are no symbolic lines with concrete beams, unlike windows. However, for anyone out there, I found a solution. Edit the profile of the tapered beam. Fillet the corners of the 2 bottom edges. If it doesn't make a sharp corner, Revit won't show those edges in plan. Presto!
pan views |
Fri, Jun 25, 2004 at 3:56:50 PM
Sloping joists to the roof deck |
Mon, Apr 4, 2016 at 11:21:15 AM
Dimensioning a Sloping Concrete Pan Joist Roof |
Sat, Feb 14, 2009 at 11:07:40 AM
joists |
Thu, Oct 11, 2007 at 4:43:14 PM
temporary dimensions require me to pan to see them |
Sat, Mar 26, 2016 at 9:52:41 AM
Members: | 2042348 | Objects: | 23026 | Forum Posts: | 152217 | Job Listings: | 3 |
