71 Users Online (70 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:17 PM
Forums >> Revit Building >> Technical Support >> Arrow into a dim string?
Fri, Jun 12, 2009 at 11:28:49 AM | Arrow into a dim string?
barcardi
So i am running a bunch of dimension strings and they look fine except a couple of the smaller dimensions are cramped by the text size of the dimension.  So i want to add a arrow and bring out the dimension a little.  Is there any way to do this in Revit?  Or could you suggest an easier way?
I'm in Revit 2010
Fri, Jun 12, 2009 at 1:01:05 PM | Arrow into a dim string?
fedup
When you select your dimension string, check the box for the "Leader" option in the toolbar. You can move your dimension around, but that will give you an arc and not an arrow. If you really want an arrow, you'll have to uncheck the "Leader" option and insert the arrow as a leader through the Symbol command in the Drafting tab.
Sat, Jun 13, 2009 at 10:00:09 AM | Arrow into a dim string?
Whoa...
Just grab the text and move it.  Revit will add a small arc from the text to where the next should have been.
You can slide text along a dimension and this arc will not happen - only when you move it outside the dimension.
partially obscurred dimension string
Mon, Oct 29, 2007 at 10:45:13 AM
Removing/editing single dimension in dimension string
Wed, Aug 26, 2009 at 7:12:02 AM
Diminsion under dim line
Fri, May 18, 2007 at 10:10:30 AM
3d dim
Mon, Jun 16, 2008 at 4:09:16 PM
Unit tolerance
Thu, Jan 21, 2010 at 5:12:10 PM
Page generation time: 0.2396
