Forums >> Revit Building >> Technical Support >> Visibility Problems
2 Posts No Rating |
Im trying to insert a glass panel screen, but it can not be visible in any floor plans, only in 3d view? im using revit architecture 09
30 Posts No Rating |
Edit the family, select the extrusion, click on 'Visibility'. A menu pops up which should look similar to the attachment. Make sure the 'Plan' view is checked and save the family. If it still doesn't show up in plan views, you might need to add 'Symbolic Lines' in plan view of the family.
Also, did you check the scale and the view mode (Coarse, medium,fine) mode? Did you check the VG???
2 Posts No Rating |
thanks guys tried both but i still couldnt get it to show... doesnt matter but thanks anyways
Can you give us more information? Is your glass panel screen a curtain wall panel, a window, a generic model a mass or an in-place family? I doubt that you problem is not solvable.
VISIBILITY PROBLEMS |
Wed, May 2, 2007 at 3:31:32 AM
visibility graphics problems-please help! |
Sat, May 28, 2011 at 4:33:53 PM
VG problems with uploaded beam family |
Tue, Aug 28, 2007 at 6:49:43 PM
HELP!!! Problems with Room Tag |
Tue, Dec 3, 2013 at 7:17:38 AM
Problems with visibility parameters |
Tue, Sep 23, 2008 at 9:01:12 AM
Members: | 2118613 | Objects: | 23200 | Forum Posts: | 152309 | Job Listings: | 3 |
