62 Users Online (61 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:17 PM
Forums >> General Discussion >> Revit Project Management >> Revit 2010 and Navisworks 2010
Thu, Jun 11, 2009 at 6:47:48 PM | Revit 2010 and Navisworks 2010
jgmas
Anybody that is familiar and that uses revit and navisworks. Do you know if navisworks support revit linked files? I know that previous versions of  revit and navisworks do not support revit link files, but I have not seen anything on the new version of both softwares.
Thanks
Also, I exported a single revit file (not linked) with a lot of curtain walls to navisworks, but when I open the file in navisworks all my curtain walls switched back to regular walls and removed some of the wall profiles I created.
Any ides?
Thu, Jun 25, 2009 at 2:17:35 PM | Revit 2010 and Navisworks 2010
Eddieboarder91
Eddieboarder91 Avatar
4 Stars: 8 Votes
exporting does not support links. make sure entire model is selected from the export settings.
www.allbimallthetime.blogspot.com
http://familyjewels.typepad.com/
Fri, Oct 9, 2009 at 1:14:49 PM | Revit 2010 and Navisworks 2010
mhans
3 Stars: 10 Votes
I'm new to Revit in Navisworks. I exported a model with wall and storefront to Navisworks and all storefronts extrude out of the wall. I also am losing the profile of the wall I editted and the top attachment to roof is also lost. Thanks for any insights.
Motto: "No Post left behind"
Mon, Mar 1, 2010 at 8:15:35 AM | Revit 2010 and Navisworks 2010
hroedel
Has anyone exported a file from Revit 2010 that includes structural framing objects to Navisworks 2010?  Those structural framing objects are loaded into Navisworks with "no level"...
However in Revit, the structural framing elements are created using a 'reference level'.  Does any one know about this discrepancy?  And if so, if there is a fix?
Revit 2010 Activity Codes and Navisworks 2010
Wed, Oct 27, 2010 at 12:09:18 PM
Export Issue from revit to navisworks
Thu, Apr 15, 2010 at 9:14:18 AM
NavisWorks Exporter
Mon, Mar 28, 2011 at 3:40:00 PM
Revit to Navisworks - No exporter in 2010
Thu, Aug 6, 2009 at 9:04:11 PM
Revit to Navisworks
Mon, Oct 12, 2009 at 5:06:25 PM
Page generation time: 3.6614
