80 Users Online (79 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:18 PM
Forums >> Revit Building >> Technical Support >> Elevation marker prefix
Thu, Jun 11, 2009 at 1:23:09 PM | Elevation marker prefix
okj1
How can I change the text on an elevation marker to read 0'-0" instead of 0"?  (I'm using RA2009).  The elevation properties dialog says the elevation is 0' 0", but that's not how it shows up on screen.  I just think it's silly to Cryingfor example) have a second floor elevation read as 12'-6", but the first floor read as 0".  It seems like there should be an option for a prefix, like what's possible for a linear dimension.
Thu, Jun 11, 2009 at 1:40:37 PM | Elevation marker prefix
Look at your project units settings - length.  The box "suppress 0 feet" has been checked - uncheck that box.
Thu, Jun 11, 2009 at 1:50:51 PM | Elevation marker prefix
okj1
Awesome.  Thanks!
Thu, Jun 11, 2009 at 4:46:21 PM | Elevation marker prefix
okj1
Actually, this won't work.  It forces all dimensions throughout the project to have the "zero feet" unsuppressed.  So anywhere I use linear dimension strings, it will affect the dimensions...so if I want a detailed dimension to just show as 2", now it shows as 0'-2".  Is there a way to divorce the way elevation markers are treated vs. linear dimensions?
Split a an elevation marker up for mulitple sheets
Tue, Oct 4, 2016 at 2:29:35 PM
Adding a reference elevation to an existing elevation marker?
Wed, Sep 17, 2014 at 7:57:47 AM
ELEVATION MARKER
Thu, Sep 10, 2009 at 2:55:40 PM
If your elevation markers on plan disappear.
Fri, Mar 4, 2016 at 3:40:46 PM
One View Elevation Marker
Wed, Jul 9, 2008 at 6:27:42 AM
Page generation time: 0.8985
