Forums >> Revit Systems >> Technical Support >> Earth 45°
10 Posts No Rating |
How can I rotate the earth pattern at 45°?
How about doing a search in the dowloads ... EARTH ... and finding a pat file there? http://www.revitcity.com/downloads.php?action=search&keywords=earth
Yes, of course. But the download don't start. When I click "click here" appear this message: ;%UNITS=INCH;%VERSION=3.0*Earth45, Earth or ground (subterranean);%TYPE=DRAFTING-45, 0,0, .25,.25, .25,-.25-45, 0.0663,0.0663, .25,.25, .25,-.25-45, 0.1326,0.1326, .25,.25, .25,-.2545, 0.1768,0.1326, .25,.25, .25,-.2545, 0.2431, 0.0663, .25,.25, .25,-.2545, 0.3094,0, .25,.25, .25,-.25
On the download page, it clearly says: " If your download does not begin in 15 seconds, Click Here to download. If your browser is opening the file up as a text file, right click the link and select "Save Target As" (or similarily worded). "
I saved the text in TXT file and than I renamed in in a *.pat file. Now work. Thanks
Edited on: Thu, Jun 11, 2009 at 7:34:03 AM
Below grade earth pattern missing |
Thu, Nov 10, 2016 at 2:58:11 AM
Earth and foundations in Architectural Elevations |
Wed, Feb 24, 2010 at 11:04:44 AM
Publish to google earth issue |
Sat, Feb 9, 2013 at 11:00:01 PM
Avatech Earth Connector. Anyone know where to get instructions? |
Wed, Feb 24, 2010 at 7:30:28 AM
Rotating a model imported into Google Earth |
Wed, Oct 24, 2007 at 8:54:53 AM
Members: | 2022554 | Objects: | 22975 | Forum Posts: | 152203 | Job Listings: | 3 |
