80 Users Online (78 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:18 PM
Forums >> Revit Building >> Technical Support >> Adjusting a hatch pattern on a family.
Wed, Jun 10, 2009 at 2:49:05 PM | Adjusting a hatch pattern on a family.
jsburt
I have created a family that is wall based, applied brick as the matterial and hatch pattern, but It will not let me move the coursing to line up with the rest of the coursing on the wall.  Any ideas?
Wed, Jun 10, 2009 at 2:53:45 PM | Adjusting a hatch pattern on a family.
4 Stars: 203 Votes
Did you try the "Align" tool?
Wed, Jun 10, 2009 at 3:07:58 PM | Adjusting a hatch pattern on a family.
jsburt
Yes, but it just moves my entire family and to the course selected.  The other strange thing is that the pattern is not starting at the bottom.  The brick pattern is starting with about a quarter brick (which is my problem).
Wed, Jun 10, 2009 at 3:09:39 PM | Adjusting a hatch pattern on a family.
erland73
erland73 Avatar
4.5 Stars: 85 Votes
 "The other strange thing is that the pattern is not starting at the bottom". You can use the Align tool for this....
Wed, Jun 10, 2009 at 3:11:01 PM | Adjusting a hatch pattern on a family.
4 Stars: 203 Votes
So, try to edit the family and use the align tool to "move" the brick pattern then save and load into project....
Wed, Jun 10, 2009 at 3:23:43 PM | Adjusting a hatch pattern on a family.
jsburt
I tried to apply another pattern within the family instead of applying it in the model and I was able to adjust it...however.  How do you get the "Brick Pattern" imported into the family editor because that is the pattern that I need to use.  I have been searching my PC for the .pat file but havent had any luck.
Wed, Jun 10, 2009 at 3:39:19 PM | Adjusting a hatch pattern on a family.
4 Stars: 203 Votes
To import a "Hatch" pattern, go to materials then in the surface patterns open and follow the image.... Model>new>custom>import, then select the folder where you have your patterns, you can go here (in Revitcity) in the download section, search for patterns and you can download what you need...
Wed, Jun 10, 2009 at 4:05:15 PM | Adjusting a hatch pattern on a family.
before this thread gets too long...
jsburt - do you know the difference between a 2d hatch and a model hatch?  If not - start by reading your HELP.  If you want to adjust hatch patterns - it MUST be a model hatch.
Adjusting the hatch pattern inside of a filled region?
Fri, Dec 5, 2008 at 11:07:41 PM
Hatch pattern on a wall
Thu, Mar 29, 2012 at 9:00:22 AM
Exporting hatch pattern
Thu, Sep 18, 2014 at 6:27:36 PM
hatch pattern not printing
Mon, May 8, 2017 at 12:56:52 PM
Hatch pattern
Tue, Jan 13, 2009 at 10:23:48 AM
Page generation time: 0.9387
