25 Users Online (24 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:17 PM
Forums >> Revit Building >> Technical Support >> Got questions about moving to 64 bit
Tue, Jun 9, 2009 at 1:44:27 PM | Got questions about moving to 64 bit
terealva
My understanding is that a model can be opened in both 32 and 64 bit operating systems.
Can you have your central model be in a 32 bit operating system and have a local file in a 64 bit operating system or viceversa?
Can you have your architectural model in a 64 bit operating system and your consultant links in 32 bit operating system?
We are trying to test a 64 bit operating system to see the benefits of it. The way we want to test it is having one person work on a model for a couple of weeks, but only that one person would be working on a 64 bit operating system. The rest of the people that would be working on the same model would be working on a 32 bit operating system. I'm wondering if that's possible at all.
 Thanks,
Terealva
Tue, Jun 9, 2009 at 3:06:12 PM | Got questions about moving to 64 bit
3.5 Stars: 401 Votes
I've talked to Mr Spot about this and he was on the beta version before 2010 came out.  Maybe he will respond later but as I understand it, both 32 & 64 can share same central ... it's a file ... it's a file ... it's a file - doesn't matter.  And that answers most of your questions.
Speed is a different issue and as I understand it, most of the time it will only show up in rendering.  The big difference will be performance on large projects.  With 32 systems... I think we are pushing it with 150+/- meg files - depending on links and worksets.
Wed, Jun 10, 2009 at 11:05:38 AM | Got questions about moving to 64 bit
coreed
coreed Avatar
4 Stars: 16 Votes
files are not operating system dependant. if your working with very large files, there are files that you will be able with your 64-bit OS that will not open with your 32-bit OS for variest rasons. but that dosen't seem to be a problem hre.
best regards,
coreed,aia
bmpArchitects,Inc.
Long Live Revit
Thinking about switching to 64 bit Revit. Got questions.
Mon, Jun 8, 2009 at 2:48:16 PM
noob with questions and some experience
Sun, Oct 4, 2009 at 5:21:38 AM
windows XP Professional x 64 bit
Wed, Sep 27, 2006 at 12:39:51 PM
64 bit revit, 64 bit vista and multi-cores... [ 1 2 ]
Sat, Apr 4, 2009 at 1:38:57 AM
29
Walls moving/ disappearing ?!
Wed, Nov 2, 2011 at 2:37:01 PM
13
Page generation time: 0.4115
