60 Users Online (59 Members):
Forums >> Revit Structure >> Technical Support >> Please Read Project falling apart!!!!!!!!!!!!!!
![4 Stars: 5 Votes](/images/stars_4.gif) |
When i select anything from a floor or a grid line or a door or column it is moving itself i dont know what i have checked that would cause this or why it is all of the sudden acting crazy. Basicly i messed up the whole project so i def have to start over. The problem is when i created a new drawing i drew a couple wall just to see and it is still doing it Please see attached
I am using Revit Structure 2010 and my file is to big to attach i think
Without some examples - we may not be able to help but there are some possible problems. Look on your options bar. Is press and drag on? Turn that off until you understand the problems it can give you. Watch out for crossing and even window selections. What you see is not necessarily what you picked .... This is a 3D world and you need to keep track of your view depths. There is something else on the otherside of that wall or floor when you pick with windows. This is why it is very important to always look in your filter (funnel) oin the options bar to see what you have picked. Finally, if you have items that have been placed with "moves with nearby elements" checked, then the item will move. Locked dimensions and alignments will also result in other items moving.
thats great i dont know how it got check but it fixed the problem thanks for the great advice
Room tags At Sections |
Tue, Jun 12, 2007 at 2:46:10 PM
falling blocks. help please |
Fri, Jan 7, 2011 at 2:25:25 AM
Parameter to read if family is flipped |
Tue, Jan 8, 2008 at 10:35:19 AM
Mirroring |
Sat, Oct 12, 2013 at 1:12:02 AM
Read Only |
Wed, Sep 28, 2011 at 8:38:28 AM
Members: | 2017265 | Objects: | 22947 | Forum Posts: | 152212 | Job Listings: | 3 |
