45 Users Online (43 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:17 PM
Forums >> Revit Structure >> Technical Support >> conc volume
Mon, Jun 8, 2009 at 2:44:03 PM | conc volume
86Supra
4 Stars: 5 Votes
if i draw walls and slab out of concrete can i calulate the volume for ordering or do i have to do it the hard way, by hand
Mon, Jun 8, 2009 at 2:45:30 PM | conc volume
Revit will give you volums.
Mon, Jun 8, 2009 at 2:48:27 PM | conc volume
86Supra
4 Stars: 5 Votes
how do i get them? by selecting the shape or what do i have to do
Mon, Apr 11, 2011 at 9:21:01 AM | conc volume
newrevituser
Hi, if you use revit architectural 2011, you can produce the Schedule/Quantities from each of your element, including volume, perimeter, area, etc.
Click on View tab -> Schedule (drop down list) -> Material Take off
Select the category of your element (i.e Floors or Columns or any other), click OK. Material Takeoff properties dialog box will appear, on the Field tab, highlight which field you want to be scheduled (i.e volume, perimeter, area, etc) and click Add -->. Click OK, and there should be a new Schedule / Quantities appear in your project browser.
Click your schedule and your quantities should be scheduled.
Hope it helps.
Creating a wall tag with a volume parameter
Sun, Jun 23, 2013 at 3:56:03 PM
Hatching a conc wall
Fri, Mar 7, 2008 at 11:49:54 AM
Calculating Volume
Tue, Sep 4, 2007 at 2:35:09 AM
Taking off material volume
Wed, Feb 22, 2012 at 4:08:50 AM
Calculate the volume
Sat, Jan 25, 2014 at 9:33:53 PM
Page generation time: 0.2229
