48 Users Online (47 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:17 PM
Forums >> Revit Structure >> Technical Support >> Selecting Objects Help!!!!!!!
Mon, Jun 8, 2009 at 2:33:25 PM | Selecting Objects Help!!!!!!!
86Supra
4 Stars: 5 Votes
I am drawing an addition onto a building and now im adding all of my steel columns and beams. Out of nowhere everytime i select an object such as a beam or a floor it tells me i need to unjoin the element so if i click okay it move my stuff all around. Why is it assosiating everything as being joined i can attach a file for Revit structural 2010 if anyone wants to look at it.
Thanks,
Lance
Wed, Jun 10, 2009 at 8:16:22 AM | Selecting Objects Help!!!!!!!
travistlo
5 Stars: 2 Votes
when you move things, use the move command. Check the option bar, there is a option for the move command "Disjoin" see if this helps.
Revit tries to act smart, it will join objects together thinking that if one moves, the other needs to move. this happens a lot with slab edges and walls, beams on structural walls, etc.
Chatting it up on gmail - travistlo.j@gmail.com
Wed, Jun 10, 2009 at 8:23:52 AM | Selecting Objects Help!!!!!!!
Be aware that when you disjoin, all tags and dimensions "joined" to the element are now lost and will disappear.  However, this is your only option in some instances.  Just be aware that you need to go back and replace the lost tags and dimensions .. in all affected views!
Selecting Objects on floor below
Thu, Nov 29, 2012 at 2:54:55 PM
Selecting-De-selecting objects.
Fri, Nov 25, 2005 at 10:12:01 PM
Revit moves objects just by selecting them?????
Wed, Jul 17, 2013 at 11:53:34 AM
Selecting objects from a list?
Mon, Aug 15, 2005 at 2:29:26 PM
Weird behavior when selecting objects
Tue, Nov 27, 2012 at 9:25:24 AM
Page generation time: 0.3680
