67 Users Online (66 Members):
Forums >> Community >> Newbies >> LED Lighting strips in Soffits
38 Posts No Rating |
The project I am working on has led accent lighting pocketed in the soffits. I built a custom solid sweep to create the illuminated tube. When I render it glows and shows up when visibile but doesn't "glow" onto the ceiling edge. I tried opening an uplight family and adding a light source definition. But how do I get the light source definition to follow the full length of the curve? I want it to indirectly light the little pocket it is in, rather than see the light source itself, so the pocket has a soft neon glow. Please give me some advice on how to achieve this. Thanks.
There is no curved light source. You either use a series of point sources or straight line sources. BTW - If the light source is inside your tube, your tube has to be at least translucent.
I am experimenting with using a series of small studio lights to try and get the effect and that seems to work. Thanks Hub.
2x2 ceiling with 6" strips at lighting inserts |
Tue, Dec 10, 2013 at 8:48:08 AM
Handrail Lighting LED Strip |
Thu, Jan 11, 2018 at 6:31:21 AM
LED Lighting |
Tue, May 29, 2012 at 10:54:24 AM
Rendering : Colored semi-transparent canopy strips |
Tue, Jan 27, 2015 at 4:49:08 PM
Do roof soffits really need to be scheduled? |
Wed, Mar 10, 2010 at 5:57:08 AM
Members: | 2017220 | Objects: | 22947 | Forum Posts: | 152212 | Job Listings: | 3 |
