50 Users Online (49 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:18 PM
Forums >> Revit Building >> Technical Support >> How do I draw Bermuda shutters?
Sun, Jun 7, 2009 at 11:45:05 PM | How do I draw Bermuda shutters?
shraddha
I have tried many convoluted ways but it doesn't work.
I have tried drawing a mass and applying a wall but,m I couldn't edit the profile of the wall.
I drew a regular wall and edited the profile to look like a shutter but, I couldn't rotate the wall to pop out like a bermuda shutter.
Please help.  I attached 2 photos.  One of my screwed up model and the other of what a bermuda shutter should look like.  I also already looked in the download menu and didn't find one already done.  If you can help me figure out how to do it I will upload the shutters to the library.
Thanks!
Mon, Jun 8, 2009 at 1:21:27 AM | How do I draw Bermuda shutters?
tim123
4 Stars: 19 Votes
I'm not sure why you would use a wall to draw a shutter.
Create a new family, probably generic.  Use a reference line to create an angle parameter.  Use extrusions to create the frame.  Use an extrusion to create a louvre and constrain it to the frame.  Array the louvre and if required, give it a parameter for number of louvres or spacing.  Give the components material parameters.  Load it into your project.
Mon, Jun 8, 2009 at 9:11:41 AM | How do I draw Bermuda shutters?
shraddha
As I said, I tried many convoluted things trying to make it happen... thanks for the condescending line before your helpful reply.
Wed, Jun 10, 2009 at 9:04:39 PM | How do I draw Bermuda shutters?
lunchtrayrider
3.5 Stars: 7 Votes
in addition to what time said you might try a wall hosted family.  might give you some different functionality you may or may not like.  also i think tim was mostly just wondering if there was a specific reason you might want to be making these out of walls.
Thu, Jun 11, 2009 at 7:53:25 PM | How do I draw Bermuda shutters?
shraddha
tim - many apologies.  i misunderstood.
thank you for the wall hosted suggestion as well.
Thu, Aug 6, 2009 at 10:25:32 AM | How do I draw Bermuda shutters?
RainaMc
RainaMc Avatar
I am trying to do the same thing.  Except I was hoping to take the shutters that I already have and rotate it for the Bermuda style, but of course that would be way to obvious and easy so naturally it does not work.  So before I continue I was just curious what you ended up doing.
Thu, Mar 11, 2010 at 11:08:28 AM | How do I draw Bermuda shutters?
RainaMc
RainaMc Avatar
"Use a reference line to create an angle parameter.  Use extrusions to create the frame.  Use an extrusion to create a louvre and constrain it to the frame.  Array the louvre and if required, give it a parameter for number of louvres or spacing.  Give the components material parameters.  Load it into your project."
How do you get the extrusion to lock to the reference plane and follow the angle?  Even if you rotate the extrusion it removes the constraints.  Please help I guess at this point my main problem is how do you get an extrusion to rotate without breaking all the parameters or for that matter a family to rotate in an elevation view.
Thank you,
Raina Mc
Thu, Mar 11, 2010 at 11:39:32 AM | How do I draw Bermuda shutters?
RainaMc
RainaMc Avatar
I got it to rotate in the family after building it and loaded it into the project.  However I still don't understand how you can get the extrusions in the family to follow a rotating refernce plane.
Thu, Mar 11, 2010 at 12:24:21 PM | How do I draw Bermuda shutters?
lunchtrayrider
3.5 Stars: 7 Votes
i believe the key here is reference line not plane.  check it out.
Thu, Mar 11, 2010 at 2:07:46 PM | How do I draw Bermuda shutters?
4 Stars: 203 Votes
Lunch is right, use "Reference LINE" not "Ref. Plane", the Ref. Lines have two Work Planes which you can select in what work plane you want to work, to "Host" the family.... then just Align the object to the ref. line and lock the padlocks....
Why doesnt Revit have shutters?
Tue, Oct 19, 2010 at 2:49:14 PM
Upgrade Your Home with Durable and Stylish PVC Shutters for Long-Lasting Appeal
Tue, Sep 24, 2024 at 6:05:35 AM
Need help finding or creating SHUTTERS
Sat, May 17, 2008 at 3:59:42 PM
Painted Raised panel shutters
Sat, Jul 22, 2017 at 9:18:16 AM
Double Skin facade with folding shutters
Tue, Nov 12, 2019 at 9:31:44 PM
Page generation time: 1.0025
