58 Users Online (57 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:18 PM
Forums >> Revit Structure >> Technical Support >> Error on rendering..Please help
Sun, Jun 7, 2009 at 3:30:27 PM | Error on rendering..Please help
4ABs
Hi all,
I have a problem when I start rendering. i never have this before...any advice???..
This is the error:
There is not enough space on drive C: to cretae the temporary file that revit needs .It is recommended that yo exit revit, either free up space on this drive or redefine windows user variable tmp to be a folder on another drive with more space, and restart revit again to help provide optimun performance.
I have 500GB of hard drive and 80% is free..
Regards,
Alberto
Mon, Jun 8, 2009 at 7:50:00 AM | Error on rendering..Please help
A few suggestions.  Have you used anything like cc-cleaner to clean your drive and delete your temporary files?
Did you start the rendering after working awhile in REVIT?   Even though you close windows, not all memory is released.  Restart REVIT andgo immediately to your rendering.
Mon, Jun 8, 2009 at 8:11:13 AM | Error on rendering..Please help
coreed
coreed Avatar
4 Stars: 16 Votes
i don't know. 400GB of free disk space should be plenty unless your trying to render one really large file with lots of lights sources and the like.
best regards,
coreed,aia
bmpArchitects,Inc.
Long Live Revit
Mon, Jun 8, 2009 at 9:24:09 AM | Error on rendering..Please help
LIZARD2806
3.5 Stars: 7 Votes
Tell us what settigns you are using, and post a screen capture of the 3D view (undrendered).  It will help in trying to help.
Mon, Jun 8, 2009 at 3:43:32 PM | WWHub
4ABs
Quoting WWHub from 2009-06-08 07:49:59
Thank you all.....
WWHUB...thanks for your help I runned the cc-cleaner and that solved the problem........now I am back on track........;-)
Regards,
Alberto
Mon, Jun 8, 2009 at 5:26:23 PM | Error on rendering..Please help
lunchtrayrider
3.5 Stars: 7 Votes
+1 for ccleaner. i use it and it keeps strange issues to a minimum.
Mon, Jun 8, 2009 at 8:26:16 PM | Error on rendering..Please help
erland73
erland73 Avatar
4.5 Stars: 85 Votes
"I runned the cc-cleaner and that solved the problem.......", you can also try with the "Advanced System care", is more complete and is free as well:
http://www.iobit.com/advancedwindowscareper.html
Thu, Jun 11, 2009 at 2:51:50 PM | erland73
4ABs
Quoting erland73 from 2009-06-08 20:26:15
I also created a different Temporary folder in windows explorer and then re-route the path for the TMP. That also works.
Thanks..
Alberto
Render Calculation Error? [ 1 2 ]
Fri, Jun 7, 2013 at 7:53:39 AM
19
Rendering authentication error
Tue, Sep 18, 2012 at 4:14:19 PM
Cloud Rendering Error: A problem Occurred, the file could not be translated. -1
Thu, Jan 2, 2014 at 12:00:50 PM
High Quality Rendering Error
Thu, Mar 26, 2009 at 3:11:24 PM
Render Error - "Unknown Error during Rendering Calculations"
Fri, May 1, 2009 at 1:52:24 PM
Page generation time: 1.7010
