63 Users Online (62 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:18 PM
Forums >> Revit Building >> Technical Support >> Linework issues
Fri, Jun 5, 2009 at 4:03:34 PM | Linework issues
Sparhawk
I am having difficulty getting the elvations to print as they appear on screen.  Finally everything is looking pretty good on the monitor ,but elements such as fascias, gutters, roof edges and wall edges dissapear randomly when printed.  Does anyone know how to address this problem?  Plotter settings?  Visability graphics?  Please help!
Fri, Jun 5, 2009 at 4:12:55 PM | Linework issues
tim123
4 Stars: 19 Votes
Have you tried printing on different printers. or PDF.  I previously had problems printing to a specific printer (OCE).  This was a driver problem rather than a Revit problem.
Fri, Jun 5, 2009 at 4:21:12 PM | Linework issues
Sparhawk
Printing to PDF does not help.  Other threads suggest a lot of linework is necessary to make the elevations and sections read correctly.  Is this common practice with Revit?
Fri, Jun 5, 2009 at 4:33:18 PM | Linework issues
You said that items disappear when printed.  This is not a REVIT issue.
You also asked about line quality.  This issue can be resolved through the REVIT settings but it does take some time to get your standards set up and to understand the "rules".
Are you vector or raster printing?  There are issues with raster printing because of the pixels.  You will sometimes see a difference between true x or y lines versus diagonal lines because of this with raster prints.
I believe the bulk of your problem is driver / printer related.  Printing to PDF should help. Listing your printer may help but you MUST be using the latest driver for your printer.
Fri, Jun 5, 2009 at 4:37:45 PM | Linework issues
tim123
4 Stars: 19 Votes
It should print as it appears on your screen.  I don't normally add any linework to elevations.  With sections you may need to do some 2D work for details as it is not practical to model everything (although it's possible).  Does printing to a different printer yield the same result?
Fri, Jun 5, 2009 at 4:49:52 PM | Linework issues
Sparhawk
Printing a PDF and to a different printer still shows the linework missing in the preview.  some of the elements were cut and pasted.  Could this be a source of the problem?
Fri, Jun 5, 2009 at 6:16:15 PM | Linework issues
Sparhawk
It looks like the problem was vector vs. raster printing, whatever that is.  Changing to raster solved the problem.  Thankyou for your help!
Can you save linework?
Tue, Aug 12, 2008 at 7:37:08 PM
Linework tool issue
Mon, Sep 26, 2011 at 3:20:45 PM
Improving Linework in Sections & Elevations
Sun, Mar 30, 2008 at 12:30:49 AM
How to delete linework created by underlay
Tue, Jan 31, 2012 at 9:45:58 AM
Linework on column woes
Fri, Apr 29, 2005 at 12:40:36 PM
Page generation time: 2.4386
