66 Users Online (65 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:18 PM
Forums >> Revit Building >> Technical Support >> how to have text on a nested family show when its in the family it is nested to
Fri, Jun 5, 2009 at 2:31:32 PM | how to have text on a nested family show when its in the family it is nested to
jcrocco
3 Stars: 1 Votes
I dont know if the subject makes sense, but . . .
What I am trying to do is make a server rack with a nested patch panel, and other equipment.  The issue is the port numbers and the lines drawn on the faceplate of the patch panel dont show up when nested with the server rack.  I had a similar issue with the ports, so I made those a void, thus eliminating that problem, but how do I do the text and lines?
Fri, Jun 5, 2009 at 3:30:33 PM | how to have text on a nested family show when its in the family it is nested to
wildrice2001
Have you tried using "Model Text"?  Its main function is to make signage, because it can be dimensional, but it should work for what you are doing.  The only drawback might be that it will only be aligned ot the face its palced on.
Nested Families and System Parameters
Fri, May 8, 2015 at 9:47:42 AM
Text Nested In Family
Fri, Jul 29, 2011 at 9:06:18 AM
scale nested family within a family (2017)
Wed, May 3, 2017 at 5:28:44 PM
Nested door family - tags wil only show in elevation view?
Mon, Aug 9, 2010 at 9:53:33 AM
Nested Family Count in Table
Mon, Jan 15, 2018 at 11:47:53 AM
Page generation time: 1.3871
