109 Users Online (108 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:18 PM
Forums >> Revit Building >> Technical Support >> massing - default color not visible
Fri, Jun 5, 2009 at 9:45:18 AM | massing - default color not visible
ceciliarch
Hello Rev community!
Why the mass is not showing its default "pink" color in the 3D view?
what I did: created an In-Place Mass\draw form\Create Form\changed Model Graphic Style to Shaded with Edges\changed Detail Level to Fine\ changed to 3D view
Result: the mass is showing without any color.
then, I Finishe Mass.
Result: the mass is still showing without any color.
Please advise!
Ceciliarch
Fri, Jun 5, 2009 at 10:12:14 AM | massing - default color not visible
tim123
4 Stars: 19 Votes
Check the material settings of default form, in the manage menu and if the masses are set to that material in Object styles.
Tue, Jun 9, 2009 at 9:28:38 AM | massing - default color not visible
ceciliarch
Thank you, Tim123.
Here are the steps I took to color a mass face:
1) Edit the material: Manage(T)/Project Settings/Materials/ select a material/ Surface Pattern:Solid Fill/RGB desired color/ Transparency 50%/OK.
2) Paint mass face: Modify(T)/Edit Face/Paint/Element/Material-select the material from 1)/ the cursor is accompanied by the paint symbol/select the face to be painted.
Note. This method is useful if needed different colors on several masses in the project. Choose one material per color you want to use. The material transparency is a nice feature.
Happy Revit to you!
Ceciliarch
how to change the default ground color ?
Thu, Feb 26, 2009 at 8:24:48 PM
Change mass colour for massing study
Mon, Nov 24, 2008 at 4:52:35 AM
Revit 2010 default highlight selection color
Fri, May 8, 2009 at 5:11:02 PM
Can I change the color of the Default Wall?
Fri, May 4, 2012 at 11:36:18 AM
Default fill region
Tue, Jun 2, 2015 at 9:11:02 PM
Page generation time: 1.7161
