Forums >> Revit Building >> Technical Support >> Stack Wall Problem
Revit Architecture 2009 I have a stack wall with both walls and the stack wall alignment set at finished face exterior. I am sure that I am doing something stupid, but I am unable to get them to line up on the exterior face. See attached. Any suggestions?
I purged unused and got it below 2Mb.
Did you try the "Offset"?
Also:
...............assuming that the alignment line had anything to do with how the different walls fit together in a stack wall. It appears that the default alignment is the inside finished face since that is how these two different width walls fit together. Is that the default? Thanks for the help. The offset tool applied to the stack worked perfectly. I have used this for sweeps in the past but the fact you could use it for stacked walls flew right over my head.
Good for you....
Stack Wall Problems! |
Wed, Feb 14, 2007 at 2:54:37 PM
More stack wall problems! |
Sun, Apr 8, 2007 at 3:40:17 PM
Quoin stack |
Sun, May 10, 2009 at 4:44:29 PM
Why are stack walls a never ending headache? |
Fri, Mar 28, 2008 at 11:16:21 AM
Stack Stone Hatch |
Fri, Nov 16, 2012 at 7:38:58 PM
Members: | 2114611 | Objects: | 23192 | Forum Posts: | 152319 | Job Listings: | 3 |
