74 Users Online (73 Members):
Forums >> Community >> Newbies >> reference plane in 2010
37 Posts No Rating |
I can't sem to find the reference plane tool in 2010. Any help? Thaks in advance. -Eric
never mind. Found it. Isn't switching versions mid-project fun.......???! e-gats
Although I don't recomment using this very often because it can become a crutch: Put this away for save keeping. It is interactive and will show you where the different commands are in 2010 relative to where they were in 2009. Just click on a command and it will jump to the 2010 ribbon. http://www.nichitecture.com/downloads/Where%20is%20my%20command%20in%20Revit%20Architecture%202010.html
also, becareful when dimensioning with your reference planes/lines turned on. You may accidently dimension to the reference plane and then when you turn it off, the dimension will disappear with it.
Also, don't forget that you can find the location of the commands with the 'Where is my command' in the drop down menu next to the help.
Tag dimensions to reference plane in 2010 |
Wed, Jan 6, 2010 at 1:41:42 PM
Defining elevation views parallel to a reference plane |
Sun, Mar 5, 2006 at 2:37:41 PM
Wrong Reference plane flexing [ 1 2 ] |
Wed, Sep 23, 2015 at 8:22:57 AM
23
PLEASE HELP!! WALL VISIBILITY/WORK PLANE ISSUE??? =( |
Sun, Jul 26, 2009 at 3:00:23 PM
Reference Plane in detail component |
Mon, Mar 5, 2018 at 8:55:45 PM
Members: | 2030530 | Objects: | 23003 | Forum Posts: | 152205 | Job Listings: | 3 |
