31 Users Online (29 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:18 PM
Forums >> Revit Building >> Technical Support >> tagging slab level and thickness?
Thu, Jun 4, 2009 at 3:09:42 AM | tagging slab level and thickness?
0myth0
in RAC 2008, is there a way to tag a slab's thickness and level, i've only been able to tag its type or family name...
Thu, Jun 4, 2009 at 6:36:50 AM | tagging slab level and thickness?
You can not create a tag that will "read" a slab thickness.  But, you can create a shared parmeter that is assigned to floors to host this value as a type parameter.  Now you can create a tag to read that.
Again, you can't get a tag to read a level.  You can do the same as above but make an instance based parameter (I think).  Levels will show up in floor schedules.
Thu, Jun 4, 2009 at 6:58:44 PM | tagging slab level and thickness?
0myth0
thanks for the reply hub, ill try it.
slab schedule
Mon, Apr 19, 2010 at 9:10:28 AM
Metal decks spanning in different directions on the same level
Mon, Nov 9, 2009 at 7:52:17 PM
Wall line thickness
Mon, Sep 26, 2005 at 5:47:36 PM
Suspended Slab problem
Thu, Aug 19, 2010 at 3:15:33 AM
Slab Thickness Tag
Fri, Aug 28, 2009 at 7:16:45 AM
Page generation time: 0.7502
