Forums >> Revit Structure >> Technical Support >> Massing - Applying Materials to Imported Geometry from Rhino-HELP!
4 Posts No Rating |
Hey, I've been having difficulty applying materials to two different masses on revit. Initially, I imported two different geometries (saving them as sat files from rhine), both imported them individually into families, and then imported them into a project. When I apply a material to one family, it automatically applies the same material to the other family. I tried so many things, and looked at all the forums but couldn't find any means to resolve this dilemma. Need help! As I need to finish my portfolio. Thanks Asharch22
With imported geometry, you are limited to applying materials via layers. This is defined in your object styles, under imported-->imports in families Your two imports must have the same named layer, edit the layer names so they are different and then you'll be able to define their materials individually.
Regards,
Chris.
Co-Founder | BIM Consultant | Software Designer B. Arch)
4 Posts No Rating |
Sorry, I'm a bit of a newbie, how do i do that?
4 Posts No Rating |
Oh and another thing, it doesn't show up as two imports when i go to object styles
Look at the bottom of this page (left), you gonna see several threads about this issue....
4 Posts No Rating |
Yeaa, maybe its just me, but im still experiencing the same problems, even after looking at the other posts...
46 Posts No Rating |
I have imported a generic model floor based (with a cad file). I have made all the changes noted in the comments above. It appears the material should be applied, but it still shows up as grey!
any ideas...is it because the cad is not fully or partially exploded. If I try this...it dissapears
the material is located under manage/materials , and listed as Render 255-120-130 (those numbers changes depending on the color) ... replace that material, and check the effect of the change in a "realistic" visualization
go to manage on the upper ribbon and click object styles. under object styles got imported objects then change the materials.
Adding a material to a mass imported from Rhino |
Fri, Oct 22, 2010 at 2:27:32 PM
Rhino imported as mass |
Tue, May 7, 2013 at 12:58:01 AM
applying revit materials to imported sketchup geometry HELP!!? |
Fri, Feb 13, 2009 at 1:22:42 PM
>>>stuck with creating massing form in revit<<< HELP! |
Fri, Nov 6, 2009 at 4:07:54 PM
Import Rhino model into Revit |
Mon, Mar 3, 2014 at 7:42:37 AM
Members: | 2100562 | Objects: | 23171 | Forum Posts: | 152294 | Job Listings: | 3 |
