127 Users Online (125 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:17 PM
Forums >> General Discussion >> Revit Project Management >> Rendering Challenges
Wed, Jun 3, 2009 at 9:12:09 PM | Rendering Challenges
Homeytheclown
Homeytheclown Avatar
3.5 Stars: 3 Votes
As the only draftsman at in the company, I wear many hats.  (except a Top Hat)  I do all the drafting, but have been since doing rendering more often.  I've found that with no traing, revit can be tough, as the case for me learing how to revit.  However, I am achieving substantial progress and am turning heads at the company.  Here are my current challenges.
1. My render time is always set to 7:30 pm 5/10 boston time.  This is the only way to get the interior and exterior lights to show up.  Whats the secret to get the lights on in the day time?
2.  Glass never shows up, why?  Glass appears to always be missing.
3.  Vehicles.  Most vehicles (and Componets) seem to be derived from a DWG, which (for me) will not allow you to assign materials to it.  How is this done?
4.  I make a material in the family, then I load it in the project.  I get the names but have to pickout the actual material textures again.  Solution?
5.  If revit is my knowledgebase for rendering, what is the best program for rendeing that is both easy to learn and all in one? (bad example being Artlantis)
Thanks all
Homey don't play that.
Thu, Jun 4, 2009 at 3:40:06 AM | Rendering Challenges
4 Stars: 203 Votes
First of all, Welcome to Revit World.....
About your questions I try to answer in a few words:
1- Try to increase the value of your (watts/Lumens) interior lights, if you search in the forum you gonna see several threads about this.
2- Check the "Glass name" you want, then go to materials and "replace" to a different glass you want, remember you can change the reflection, color, ...... for the glass. (there are several posts here in the forum)
3- Yeah, i think 90% of the vehicles are from CAD programs BUT you can change the materials (glass, tires....), pick in that "Car", "edit Family" go to Settings>materials and check the names you have there for the several parts of the car, if you want you can change in there OR in the project in materials change. (there are several posts here in the forum)
4- Like the Same in the "Cars". (there are several posts here in the forum)
5- I always render in Revit BUT 3DMAX it's also a good solution, again, there are several posts here in the forum
Thu, Jun 4, 2009 at 8:59:15 AM | Rendering Challenges
erland73
erland73 Avatar
4.5 Stars: 85 Votes
1. See attached....
3. Once again...http://www.revitcity.com/forums.php?action=viewthread&thread_id=14101
5. "what is the best program for rendeing that is both easy to learn and all in one?" What about Rhino?......
Thu, Jun 4, 2009 at 7:23:44 PM | Rendering Challenges
Homeytheclown
3.5 Stars: 3 Votes
Thanks all, this turned out to be easier than that chick I dated in high school.  I think all has been solved.  Thanx!
Mon, Oct 18, 2010 at 2:38:37 PM | Rendering Challenges
Homeytheclown
3.5 Stars: 3 Votes
In retrospect, the answer was the 'adjust exposure' button in the Render Tab.
Stair Landing & Door Swings
Wed, Mar 2, 2005 at 10:49:03 AM
Realistic Rendering [ 1 2 ]
Thu, Aug 4, 2011 at 2:30:37 PM
25
2 Days Rendering...38% Complete 2009 Slow Rendering [ 1 2 ]
Wed, May 13, 2009 at 7:36:39 AM
22
09' Rendering Issue
Wed, Jun 3, 2009 at 4:22:51 PM
11
Going from Rendering in RA 2008 to Rendering in RA 2009
Mon, May 11, 2009 at 4:32:50 PM
Page generation time: 0.5115
