68 Users Online (67 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:17 PM
Forums >> Revit Building >> Technical Support >> off center roof ridge
Wed, Jun 3, 2009 at 11:07:23 AM | off center roof ridge
Sparhawk
 While modeling a house I have noticed the ridge on the primary roof is not centered.  For some unknown reason the bearing height on one side is slightly different than the others.  The beraring walls are diffent types on each side but the settings are the same.  Does anyone know how to center the ridge on the span?
Wed, Jun 3, 2009 at 11:13:03 AM | off center roof ridge
tim123
4 Stars: 19 Votes
It could be for a number of reasons.  The most likely is that you drew one slope defining edge by picking the wall and the other as a line, causing different springing points.  Another is that the angle of the two slopes is not the same.  Another is that the one edge is set lower than the other when drawing the outline.
Wed, Jun 3, 2009 at 11:15:15 AM | off center roof ridge
lunchtrayrider
3.5 Stars: 7 Votes
im taking a stab at this for you so if it doesn't work say so.  if you go into the sketch of the roof (im assuming you sketched a roof by footprint) select the lines and then go into the element properties.  in there set the offset from roof base to the same number.
Wed, Jun 3, 2009 at 11:39:22 AM | off center roof ridge
Sparhawk
Thanks,  I did not think of properties for individual lines of the roof sketch.  They were set with different off-sets.  That was a big help.
Wed, Jun 3, 2009 at 12:37:25 PM | off center roof ridge
lunchtrayrider
3.5 Stars: 7 Votes
saaaweeeeeetttttt
ridge control on a sloped roof
Tue, Jul 3, 2012 at 12:18:42 PM
Can a sweep be applied to a roof ridge to model ridge capping??
Mon, Feb 4, 2008 at 11:01:27 AM
11
Roof Ridge
Tue, May 9, 2006 at 1:15:59 PM
Inserting a sklight on a ridge.
Mon, Jul 19, 2004 at 9:48:15 AM
How to model a Ridge & Hip Tile on the roof?
Thu, May 10, 2007 at 10:23:39 PM
Page generation time: 0.7419
