43 Users Online (41 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:18 PM
Forums >> Revit Building >> Technical Support >> Is anyone successfully importing dwg's without problems?????????????????????????
Wed, Jun 3, 2009 at 9:59:11 AM | Is anyone successfully importing dwg's without problems?????????????????????????
Hogmodo
Hogmodo Avatar
3.5 Stars: 6 Votes
Using 2009 after backing off of 2010 (too many crashes):
Previously, I tried to insert a bunch of standard details created in Autocad and had horrible things happen.  Dimensions disappeared, text changed, lines went away, etc.  I did the work around of just creating a phantom sheet in Revit and just printing in Autocad the typical detail sheet and inserting that into the drawing set.  I could make each of the dwg details a jpeg and insert them as an image but that creates scaling problems.
I am curious if anyone is using dwg's, either from their old files or those created by vendors, and successfully inserting them into their Revit project file?
Wed, Jun 3, 2009 at 11:27:35 AM | Is anyone successfully importing dwg's without problems?????????????????????????
lunchtrayrider
3.5 Stars: 7 Votes
i've done it but any text or dimensions will be tough to make right.  make sure to purge the autocad file really well and make sure that it is flat (not 3-d) for the best chances.  Also I delete lines that are not supposed to show up (like defpoints etc) in autocad before importing.  if you use the 'overkill' command in autocad that can help too.  and I always make sure the files are 'linked' not imported.
I like scooters. and motorcycles.
Wed, Jun 3, 2009 at 12:39:14 PM | Is anyone successfully importing dwg's without problems?????????????????????????
We do it but cautiously.  There was a post just last week that linked to another site dealing with the issue of linked CAD files.  Here is part of their advice:
A Five-Step Process for Reducing DWG Links
The five steps for reducing DWG links in a Revit project are:
  1. Define how the DWG will be used.
  2. Clean the DWG.  (Wblock works best to isolate items)
  3. Create a Workset for each link in the model.
  4. Link/Make Family/Import the DWG information.
  5. Update/Remove DWG links.
The most imprtant issues here are cleaning the file up.  Especially if you are importing.
If inserting, reduce your layers, delete all hatches, explode blocks and I delete all leaders / arrows and dimensions.  Also delete all curved polylines because they will come in as small line segments. After inserting, add dimensions and text leaders.
Problems importing .dwg or .dxf.................................
Mon, Feb 25, 2008 at 11:12:14 AM
not to see imported dwg on every level (after importing dwg)
Sun, Nov 26, 2006 at 11:13:59 PM
3D DWG as a Mass - Visibility Problem
Fri, Sep 5, 2014 at 1:30:54 AM
Help - Importing 3D Bentley to Revit (.dwg or .dgn to .rvt)
Mon, Jun 2, 2014 at 7:53:21 AM
Importing DWG with clipped blocks
Mon, Sep 17, 2012 at 12:00:45 PM
Page generation time: 15.4320
