Forums >> General Discussion >> Revit Project Management >> need example of interior walk through
8 Posts No Rating |
anyone have an interior walk through i can show someone as an example of what can be done? like an avi file? thanks!
I looked at a very short file I had - not rendered - and it was 125 meg..... Can't post or even email it.
http://www.youtube.com/results?search_type=&search_query=revit+walk-thru&aq=f
8 Posts No Rating |
thanks for the examples and help. so on this note i have another question. once i establish the cameras, their angles, etc. and the walk through is complete in black and white, how do i go about rendering it. do i just do the rendering when i export the file, i know this window comes up and you can choose black/white, shading, shading with edges, render. Or do I do the rendering process at a different time. And how do I avoid it taking forever to render the walk through. do I have to render every frame? thanks!
Like you said, when you create the walkthrough you can choose Hidden, Shading, shading with edge or RENDER, so... "And how do I avoid it taking forever to render the walk through." - my advise, use MAX to do that.....
max will be faster, if thats not an option get the fastest/most cores computer you can to do the animation
Rendered Walk through |
Mon, Nov 22, 2010 at 4:58:09 PM
walk thru avi files |
Tue, Aug 22, 2006 at 5:52:54 PM
Walk thru |
Wed, Apr 29, 2009 at 9:41:48 AM
Can I create a walk around? |
Sat, Mar 17, 2012 at 1:29:47 AM
Walk-Tool |
Thu, Apr 9, 2009 at 8:07:43 AM
Members: | 2102344 | Objects: | 23173 | Forum Posts: | 152296 | Job Listings: | 3 |
