51 Users Online (50 Members):
Forums >> Revit Building >> Technical Support >> sloped annotation symbol text
1 Posts No Rating |
Any way to slope the text in an annotation symbol with the leader line ??
The standard annotation text is either horizontal or vertical. Can't seem to change it.
Any ideas how this may be done other than a blank annotation symbol with text at an angle written over it? (currently what I do)
Why can't you just rotate the symbol?? I'm not having any trouble rotating symbols here...
3 Posts No Rating |
I NEED HELP ON THIS AS WELL...
I CANT SEEM TO ROTATE IT.
MY ISSUES IS ROTATING IT AS 180 DEGREES. I KNOW THERE IS A WAY BY CLICKING ON THE 'ROTATE WITH COMPONENT' OPTION. BUT IT IS GRAYED OUT, SO I CANT CLICK ON IT. IS THERE A WAY TO UN-GRAY IT?
THANKS IN ADVANCE!
Need more information. Is this a nested annotation symbol? What is it?
3 Posts No Rating |
I AM TIRING TO ROTATE THE SPOT SLOPE SYMBOL.
AFTER I FIND THE SLOPE, THE DRAWING IS GOING TO ROTATED TO LEFT 90 DEGREES, ON THE SHEET. IF THAT IS THE CASE THE TEXT FOR THE SLOPE WILL BE 180 DEGRESS, UPSIDE DOWN.
I WOULD LIKE TO FIND A WAY TO SEE THE TEXT UP RIGHT WHEN ON THE SHEET.
THANKS1
If the view is not normal now, then rotate the view, then place on the sheet. You can read about rotating views in your HELP. Simple pick the crop region and rotate the view. All text will remain "normal" to the screen.
3 Posts No Rating |
thanks!
i saw the answer.. but was busy to finish up the job that i couldnt log in.
Annotation Symbol Text - Keep Vertical? |
Thu, Dec 15, 2011 at 3:23:42 PM
2D nested annotation symbol doesn't show when family is sloped in 3D |
Tue, Aug 2, 2011 at 2:58:56 PM
Annotation Symbol |
Wed, Jan 23, 2008 at 6:36:59 AM
Rotating text/label within annotation symbol |
Mon, Oct 26, 2015 at 7:19:59 AM
Generic Annotation symbol |
Mon, Dec 5, 2011 at 4:02:48 PM
Members: | 2042232 | Objects: | 23026 | Forum Posts: | 152216 | Job Listings: | 3 |
