103 Users Online (102 Members):
Forums >> Revit Building >> Technical Support >> need some help on extending wall layers?
im creating a bathroom wall with tile on both sided, because there are two bathrooms that share that wall. However, I do not want the tile to go up past the ceiling, however revit is only allowing me to unlock one side of the wall to adjust its extensions. when i try to unlock both sides it pops up a errer message that says, "Extension Layers at the top of the wall must be adjacent" anybody got any ideas??
J. Allen Ball Revit Architecture 2010 Certified Professional |
I posted on this just a week or two ago ... gotta think out of the box. Don't unlock the exterior skin - unlock all the interio ones. Now make the wall the height of the tile and pull the rest of the wall up. http://www.revitcity.com/forums.php?action=viewthread&thread_id=16153 We actually don't include the tile on our walls. We add the tile as a thin veneer wall and join it with the base. This gives you a lot more control and options.
Very Nice Hub, when you say you just add it as a thin veneer to the base, you mean like a wall sweep? or a totally different wall?
i got it figured out, thanks hub!
wall layers not wrapping at curtain wall inserts! |
Fri, Mar 4, 2016 at 10:27:08 PM
How to maintain wall height when using Roof by Footprint and extending roof... |
Thu, May 18, 2017 at 4:50:11 AM
Scheduling Wall Layers |
Wed, Nov 4, 2015 at 11:24:08 AM
modified wall assembly (using cut profile) not showing correctly in 3D view? |
Tue, Mar 1, 2011 at 2:18:48 AM
Extending Wall finishes/Walls not joining |
Wed, Dec 3, 2008 at 12:13:37 PM
Members: | 2042348 | Objects: | 23026 | Forum Posts: | 152217 | Job Listings: | 3 |
