37 Users Online (36 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:17 PM
Forums >> Revit Structure >> Technical Support >> CAN'T SEE...
Fri, May 29, 2009 at 6:01:36 PM | CAN'T SEE...
TONY121
I am unable to see my timber beams in a structural framing plan.  I have checked the view properties and view range and everything is set to what it should be. This is not just occuring on one level but multiple. Does anyone have any ideas why the beams are not visible?
Sat, May 30, 2009 at 5:11:25 AM | CAN'T SEE...
4 Stars: 201 Votes
Did you try to change the "Coarse" mode to "Fine" mode???
Mon, Jun 1, 2009 at 1:52:05 PM | CAN'T SEE...
TONY121
This did not work. I must also say that if I try to place a structural beam in the plan it does not show. Does anyone else have any suggestions?
Mon, Jun 1, 2009 at 3:40:39 PM | CAN'T SEE...
alabaster2513
alabaster2513 Avatar
3.5 Stars: 25 Votes
have you verified their elevation by cutting a section?
Mon, Jun 1, 2009 at 3:54:54 PM | CAN'T SEE...
TONY121
After my last post I did this and was able to solve my issue. Thanks.
''Visibility grafics'' and ''create parts'' problem when mak
Fri, Mar 19, 2021 at 11:45:46 AM
Add ''scale'' on a drawing list, when it is not under ''available fiel
Thu, Jan 12, 2012 at 8:35:32 AM
'Out of Memory' pop up
Tue, Sep 6, 2005 at 3:16:07 PM
Sheet # of 'total number of sheets'
Fri, Nov 16, 2007 at 6:59:54 AM
When use ''door opening'' dasced lines present only at 1:50 but not at 1:400 f.e
Fri, Jun 11, 2021 at 7:44:53 AM
Page generation time: 0.4859
