Forums >> General Discussion >> Revit Project Management >> How to create a template from an existing project that has worksharing enabled?
I am told this cant be done, even Revit errors say it cant be done. Is there a way to turn off worksharing to allow me to save as a template file? I tried this through the local Revit file. Would the same error happen if done through the central file?
Look in your HELP using for the search "transfer". You can accomplish most of what you want with this.
Thanks, I did that. The problem is that allot of stuff in the project browser didnt come over, like the views and the pipe types, and families. I remade the views. The families are allot more work to import all of them used on the previous job, but I can do that, but what I dont know how to do is transfer the pipe types. It shows up in the system browser under families, but is not a family. I have 13 pipe types. Do those have to be created? There may be more missing, I dont know yet. I keep finding more stuff as I go.
For transfering some families, I just copy a group of them from one model and paste them in the other. I unclude hosts if I have to. Then after they are pasted, I delete them all and now I still have the families.
+1 to wwhub. I do it the same way.
Trying to make a template out of a project that had worksharing enabled |
Thu, May 28, 2009 at 2:03:54 PM
Project Template |
Thu, Oct 28, 2010 at 10:50:07 AM
Worksharing |
Thu, Mar 9, 2006 at 12:29:16 PM
how to convert a template to project file in 2012 |
Fri, Aug 2, 2013 at 2:58:23 AM
Creating a Project Template file - Revit MEP 2009 |
Mon, Jun 29, 2009 at 10:39:38 AM
Members: | 2114629 | Objects: | 23192 | Forum Posts: | 152319 | Job Listings: | 3 |
