54 Users Online (53 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:18 PM
Forums >> Community >> Newbies >> help log building
Thu, May 28, 2009 at 1:04:42 PM | help log building
matador
hi im really newbie around here and revit at all....
 well, the situation is following- i have beenstarting to project log buildings on archicad with artlogs but that means that i have to work with archicad v6,5 and after first kemping house i found it really NOT interesting....
well than now i think that revit could have really high potential for that. for vizualization it's ok but i need everything for production, like detalization of each log and nc code etc.....
and i cannot find out how to do that, yes i've seen a lot of log houses, but none till now with detalization of logs.. Sad
 and maybe you could say if revit is real place to do that at all(i'm using revit 2010 arcitecture), and maybe you could suggest right place if you know some better or easier, cuz archicad 6,5 is like from stone age :D
thank you allready Smile
Thu, May 28, 2009 at 1:49:01 PM | help log building
4 Stars: 203 Votes
Hi and Welcome to Revit World, this is what you want? http://www.revitcity.com/gallery.php?action=view&gallery_id=174
Thu, May 28, 2009 at 2:03:04 PM | help log building
matador
well regreably i have to say that no... Sad
i found it earlier but it is a simple wall inside so it has only log vizualization..i would like to get more details out of it, cause i'm more technical drawer for cnc machines, positioning for every log where it should be, and so on....
but really thanks for helping Smile
Thu, May 28, 2009 at 2:11:16 PM | help log building
4 Stars: 203 Votes
Well, sorry for hear that but, that's a workaround if you need that...
Thu, May 28, 2009 at 3:44:20 PM | help log building
jarosa
jarosa Avatar
4 Stars: 5 Votes
If you want to have a material take off schedule then you will have to create a parametric family for the logs. Create a type for each log length and detail. You could have a parameter for length, diameter and even notches. Of course you can insert the same type when the specifications are the same. Windows and doors are hosted by walls so create a void, insert a wall, insert the window/door. It's a lot of work but may be the only way to get the info your looking for.
I'm not familiar with getting data from Revit or CAD to CNC.
LOL,
John
Thu, May 28, 2009 at 3:52:45 PM | help log building
lunchtrayrider
3.5 Stars: 7 Votes
I think you would have to make every log as its own family.  I'm not sure there is a better way.
Log walls
Tue, Jan 17, 2012 at 5:40:42 PM
log walls
Thu, Mar 19, 2015 at 12:14:41 PM
Log Cabin Trap Windows
Sun, Sep 21, 2008 at 9:02:22 AM
Walls for log cabins
Tue, Jul 26, 2005 at 6:09:07 PM
log walls
Wed, May 4, 2005 at 3:04:05 PM
Page generation time: 1.0470
