73 Users Online (72 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:17 PM
Forums >> Revit Building >> Technical Support >> fascia on two different sloped roofs
Thu, May 28, 2009 at 11:22:17 AM | fascia on two different sloped roofs
RainaMc
RainaMc Avatar
Hello all,
Still in 2008.  One roof is at an 8:12 and the other is at 10:12 and I have put a 1x8 Fascia board on using the host sweep-roof fascia command.  How can i get them to join correctly?
Thu, May 28, 2009 at 11:30:45 AM | fascia on two different sloped roofs
I doubt that you can.  Correct it in the 2d view using 2d tools.
Thu, May 28, 2009 at 11:52:35 AM | fascia on two different sloped roofs
RainaMc
RainaMc Avatar
All right that is what I am currently doing.  In the future should I do something different when creating the roof so I don't run into this problem?
Thu, May 28, 2009 at 11:58:56 AM | fascia on two different sloped roofs
You could problably do a sweep in place.
Thu, May 28, 2009 at 12:19:24 PM | fascia on two different sloped roofs
RainaMc
RainaMc Avatar
What do you mean?
Thu, May 28, 2009 at 12:35:01 PM | fascia on two different sloped roofs
4 Stars: 203 Votes
A Create-in-place with a "Solid Sweep" in the category you want....
Thu, May 28, 2009 at 1:01:04 PM | fascia on two different sloped roofs
RainaMc
RainaMc Avatar
Oh okay I know what you mean.  I will give that a try.
Thanks
Fascia on Sloped Glazing
Tue, Aug 23, 2005 at 11:58:53 AM
Sloped Roof Fascia
Wed, May 29, 2013 at 1:23:20 PM
How to miter a fascia on a sloped roof?
Fri, Aug 24, 2012 at 7:48:23 AM
Sloped Fascia
Thu, Apr 24, 2008 at 8:25:05 PM
Roof Fascia On Negative Sloped Roof
Wed, May 15, 2013 at 9:47:35 AM
Page generation time: 0.4022
