58 Users Online (55 Members):
Forums >> Revit Building >> Technical Support >> Area Schedules showing Metric and Imperial
3 Posts No Rating |
Does anyone know the best way to show Sqm and Sqf in Area Schedules? Tags give you the option to show both, but schedules don't seem to do the same - is this correct? Cheers
You can add a calculated parameter to your schedule to show both - convert sqm to sqf with a factor of 10.764.
3 Posts No Rating |
Thanks Tim - this works, however I can't seem to get the 'm2' to either hide or be changed to 'Sqf'. I get an 'Inconsistent Field' warning if I try to change the field to 'Number' from 'Area'. Can this be fixed? Either way, this is better than nothing! Thanks again
You can format it to show sqft rather than sqm - I forgot this - it will calculate this for you, so just have a parameter called Area sqf (=area) and overide the units to show sqf.
3 Posts No Rating |
ahh, got it...finally. For anyone else interested, you change the units in 'Field Format' under formatting for the relevant parameter. Thanks Tim.
showing metric and imperial elevations |
Thu, Jun 3, 2010 at 3:34:46 PM
Change from Metric to Imperial |
Sun, Feb 17, 2013 at 9:26:03 AM
Imperial metric question RAC2009 |
Fri, Jan 9, 2009 at 11:35:51 AM
Imperial to Metric |
Fri, Aug 8, 2008 at 4:11:17 PM
Imperial and Metric sheets and views |
Thu, Dec 16, 2010 at 3:32:05 PM
Members: | 2056243 | Objects: | 23069 | Forum Posts: | 152281 | Job Listings: | 3 |
